ONEX #54 Web Site
Date:  10-27-2013
Number of Hours:  3.00
Manual Reference:  W12
Brief Description:  Prep left indb wing skins
Deburred and smoothed the edges of the left inboard skins.
Ordered some hardware from Aircraft spruce in preperation to close the inboard wings.
Before closing the wing, I need to decide what to do about a wing tiedown point. AirWard sells a Onex tie down kit that uses a 5/16" anchor nut attached to the inboard main spar flange and screws an eyebolt into the nut when required. Sonex aircraft use a bracket attached to the main spar with an AN46-7A eyebolt attached for a tiedown. The factory Onex apparently drills a hole in the end of the locking lever as a point for a tiedown. This is not shown on the plans. So, a few options to think about.
Many thanks to Sonex builder Mike Smith for providing details about the Sonex tie down bracket.
